- 9 Jul 2013
First time ive downloaded MSI AB. Where is the option for in game OSD?
In the optionsPress 'settings' and look at the tabs
Did you install Rivatuner when you installed AB?
ED: Okey dokes, you know what you gotta do![]()
Nope, are you using version 4.0.0?
The "fix" for that is to change the update checker to never check for updates.
I know that but it's annoying that it has just started occurring with no explanation as to why
Its normal after not getting new versions of MSI AB for a while, there seems to be a set expiry thingy going on with it, its happened before.
