- 13 May 2003
- Warwickshire
I'm now thinking it looks like pine?
Really not sure and don't know how to check. I assume it's soft wood, but that's only because they tend to be cheaper and I can't imagine anyone having invested in premium boards, based on what I know of the house.Still can`t decide what wood it is!
Do you know if it is hard or soft wood?
The latter, partly because it was difficult and very dusty, but partly also because of what @Mercenary Keyboard Warrior said.Are you sanding right back to get rid of all the dents or just removing the clear coat?
Good to hear, thanks!I've used the Osmo Polyx oil on both my front room and stairs. Loved the results. I think I went with semi-matt too.
However yours seem to be nicely laid
His floorboards are immaculate compared to mine. Most of mine have been removed (with a crowbar by the looks of things) and laid/relaid with very little care.
I don't think whoever installed the heating in my house even owned a saw - most of the boards seem to have been cut with a chisel! I ended up ripping the whole lot out and putting down brand new boards - made the sanding faster, anyway!
