OSX 10.5 booting issue
19 Jul 2005
S. Yorkshire
I think I may have borked the MAC Mini we have here.:(
I was copying a DMG of the OS installation DVD, and dropped it at the root. Then trhough my total newbieness, I launched the DVD.
Now when I boot the machine, it gets to the grey screen with the apple logo, and doesn't progress any further.
I have tried booting from the DVD by pressing C and then selecting the hard drive as the boot device, but this doesn't change anything.
I've gone into single user mode and had a look at the volumes, and there are three showing. The HDD, a network share, and "MAC OS X Install DVD" which shows as a directory.
Now this is without the DVD in the drive, so I think it is the last volume that is causing the issue.
Is it trying to boot of a phantom volume?
Can anyone suggest how I can rectify this without having to rebuild it?
Cheers
Is that a different disc than the install disc?
No.
To run the Apple Hardware Test, you must start up from the disc or volume containing the test:
* If you have an Apple Hardware Test CD, start up from it as you would any other bootable disc:
1. Insert the Apple Hardware Test disc that came with your Mac into your Mac's optical drive.
2. Restart your Mac using either of the following methods:
  • o Select Restart in the Apple menu.
  • o Press the Command-Control-Eject keyboard combination.
3. Immediately press and hold the C key on your keyboard.
4. Release the C key after the Apple Hardware Test appears on your display and indicates that it is loading.
