Out with the old...
Permabanned
9 May 2005
NE8
Before:
1200cc, siamese-port, all-iron Opel lump. Circa 40bhp at the wheels.
Engine sits behind front axle line too ;) ;D
Rather happy I must admit.....
First lift in:
*n
And look at the charger outet and start of the new water rails 8-)
Nip and tuck to the chassis rails to clear the charger, all boxed in with decent spec 2mm steel....... does help to have a full fab shop on hand ;D
All welded in by IRSM...... the only mods needed in the engine bay
*n
New engine mounts all welded in as well
And finally Tunnel chopped out to clear the type 9 box
Will reposition lever hole over the lever and fabricate some infil panels to suit ;)
Cheers
Dom
:D
*n
What we have here, ladles and gentlespoons is a 1600 Zetec SE running an Eaton M45, Jag chargecooler, 10.2:1 Static CR, DTA S60 ECU (latest version now has full traction control ;)), Honda S2000-based all-Titanium exhaust.
220-230bhp expected at 9psi from the lump...Not bad in something weighing about 800Kg with fluids and driver ;)
*n
What I love is how OEM the blower install looks - Ford should run them like this from the factory ;).
Check the fab work between blower and chargecooler...It's just a pity that the chargecooler has to have the text upside down :(
*n
paradigm said:
Thats going to shift some then! :cool:
I guess the welding on the tubing betwixt charger and cooler was home-grown? Looks mighty-impressive work!
A local engineering firm, I think.
If not then 'done at work' ;)
*n
*n
I kinda like the look of the writing upside down, makes you look at it and think...... "hmmm, something is afoot" ;)
*n
Very nice, the SE is an excellent engine, but I'm wondering why you didn't "keep it in the family" by going for a 1.6 XE?
What sort of torque are you expecting? Are you running a stock Type 9? Is this too many questions?
Stonedofmoo said:
A 1600 :confused:
Why not a 2litre? :confused:
Why not a honking great big 5 litre V8? Why not a Rolls Royce Meteor/Merlin in fact?
The Zetec SE is an all alloy engine, developed by Yamaha & Mazda. It's light, compact and has lots of potential. The 2.0 Zetec E is iron blocked, so heavier to start with and larger as well.
Stonedofmoo said:
A 1600 :confused:
A 1600 Zetec SE is about 82Kg all-in.
You're looking at over 118Kg for a Zetec E (without ancilliaries).
Hehehe - not mine. Wish it was though ;)
Although...Something like this may yet appear around these here parts...
The engine above has a completely stock head and internals...
Although the 16XE is a nice wee lump, you're limited to around 180bhp by the head and bottom end.
It's a stock Type 9, running through a Manta A axle (good for about 230 lb/ft) which will be replaced in the new year by a properly four-linked Isuzu Piazza Turbo LSD-shod axle (good for nearly 300 lb/ft).
I think Dom's mentioned a round 200 lb/ft before.
...Need to wait until it's running (three weeks or so...) before it can be dyno'd properly.
*n
