Outdoor IP Cameras
7 Apr 2004
Hi,
(Hope this is the correct forum)
Can anyone recommend an outdoor IP camera for a cctv security setup? I need one that has a good 'focus' range, if that's what its called. The main point of focus will be about 30 yards from the camera, but if possible i would like to be able to clearly identify objects up to about 100 yards from the camera, by clearly identify I simply mean pick out a car or something easily enough behind a fence, while keeping 'facial identification' quality from 10-30 yards from the camera.
Is this possible with IP Camera technology? Or should i stick with analogue :confused:
I'm planning on running a couple of these cameras into a switch, then into a processing/output pc.
Budget is about £1000 for 2 cameras.
Thanks for any advice,
Jack
id be interested in this also, i had 2 grands worth of damage to my old car by my local neds, sold the ******, bought a better one and garage, but id love to have some eyes and ears on the street to keep an eye on some of these wee scumbags strolling down our street.
I don't know much about cameras so cannot advise what you would need for that focal range but I can say analogue or digital will make no difference - it's the lens your interested in, if an analogue camera can do it so can a digital.
Axis make some of the best ip cameras for security purposes.
Got one myself cost about £150 i think, looks like a full on CCTV camera aswell, and its an outdoor one with IR :p but we aint mounted it to the house yet :/ only tested it lol and it worked fine and at night with decent quality at about 100ft i think, im at work so not sure where we got it or the specs on the camera lol will check for u when i get home, but i wont be able to post the shop as it would be a competitor :rolleyes: but search for ip cameras on google.co.uk and you should find a lot and affordable ip ones, defo worth it, we got one after ove £1k of stuff was stolen from back of GF's car :(
bear in mind you don't need an 'external' camera as such - you get the best camera for your needs and put it in an external enclosure (makes it safe, keeps it dry and warm and provides power).
