I use a Shelly Mini module in the back box of the light switch. https://shellystore.co.uk/product/shelly-1pm-mini-gen3/
Normal light switches, normal light fittings, normal bulbs. Maximum flexibility, minimum price.
They are an absolute doddle to set up and integrate into home assistant. The normal light switch works as well as the ‘smart’ control.
I’m sure there are Zigbee alternatives which are similar.
I get why you might want smart bulbs if you want colour changing but for anything else, light switch modules are the way forward.
