Hi all,
As title. My outside tap has suddenly stopped working. I think it's the non return valve but I'm checking with the OCUK collective before trying to change it myself.
I turned off all water then removed the outside tap, turned the water back on but nothing came out of the pipe. Inside the garage where the tap leads to I have a non return valve and an isolation valve. Can isolation valves fail?
Is this a DIY job or should I get a plumber in? I'm a bit concerned I don't have much movement in the pipe to remove and reinstall it...
See below:
Thanks!
See below:
Thanks!
