Hi,
We've got an outside tap and it is working but the flow is pretty low and always has been.
In the picture the spur on the left is the outside tap, the next one along is the cold feed to the kitchen sink and the one on the right is the hot feed to the sink.
The sink has a flow of 520 litres an hour on the cold feed, so that's my baseline of what's possible.
The limitation seems to be the tee junction with the shut off valve, it's 15mm pipe but internally the junction to the bottom spur is very narrow.
I need to achieve a flow of 500 litres per hour outside, 600 would be even better but unlikely.
I'm thinking replace the tee junction with a proper tee compression joint and then run some 15mm pipe but step it up to 22mm and install a full bore 22mm isolation valve and a 22mm full bore double check valve. Is it worth doing this step up in order to minimise the obstruction that the isolation and double check valves will cause?
Then I thought either replace the existing 15mm tap connector with a 22mm full bore (19mm) one, which will hopefully give me a similar flow to the sink of about 500 litres per hour despite the resistance of the various valves.
Or even replace the flexi tube with copper pipe reduced from 22mm to 15mm once the valves are cleared, that might allow me to exceed the 500 litres per hour seen at the sink as that is through the 15mm flexi connector.
Will I get decent flow from this set up?
How restrictive are the double check and isolation valves likely to be? Is it worth going for large bore 22mm valves instead of the 15mm which seem to go down to 10mm or less internally?
Thanks
Edit - oh and the current outside flow is 180 litres an hour
Thanks
