Oven Trick
6 Dec 2012
notts
Daughter has a lenovo ideacentre 27 (its an all in one come giant tablet)
it would not start and after checking the lenovo forums it seems lots of folk have had this problem, lights flash on the front and fans spin, thats all we got.
seems a new motherboard is where everyone ended up, so it was time to try the oven.
i put the motherboard on some standoffs and in a tray, got the oven to 200 and put it in for 12 mins, it now works a treat and we have punished it for 3 days now without a hitch.
so my question really is, have you done it and has anything you have done lasted any length of time.
thank you.
I remember doing this with some old nVidia cards a few times, worked pretty well.
Go on put us out of our misery, what is the rationale behind why this works?
It heats up the solder and causes it to reflow to fix any dry / dodgy joints. It's basically using your home oven as a reflow oven.
Did it with a GPU many years ago, lasted another few years following the process and I have no real idea why.
Thx for the answers, how accurate do you have to be with temperature? I can imagine a little too high and you shag the board.
i put it with the components facing up hoping that would stop them falling off, i have been lucky i suppose but nothing to lose really.
the tablet has an hdmi in so if it does die the thing still works as a 27 inch monitor.
I worked as a PC tech for a couple of years and tried this a couple of times, it worked but didn't last long maybe a few days. I would bet yours will do the same, just depends though.
It's called reflowing. They actually use this method in the making of the motherboards although as you can imagine it's all clinically done.
to be honest it was a fun thing to do,
when i put it back together and it worked i was really overwhelmed, its a moment i will fondly remember for a long time.
I put my phone in the oven on about 100 degree for 30 minutes after giving it a good rinse when I drop it in the toilet, phone still works so the oven is a great medic for electrical parts
