Hi,
Just overclocked my q6600 to 3.096ghz, using 344*9, and a vcore of 1.3375V.
I used a 1:1 fsb:dram ratio, and my ram is set to read timings from SPD, and i just wanted to check they look correct or if i should enter them manually.
Ram is: OCZ 2GB (2 x 1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC
CPUZ says:
DRAM Frequency: 344Mhz
CAS# Latency: 5.0 clocks
RAS# to CAS# Delay: 5 clocks
RAS# Precharge: 5 clocks
Cycle Time: 15 clocks
Command Rate: 2T
DDR voltage is at 2.0volts
Also whats the maximum safe temp i can run the q6600 at without risking any damage? Is 50-60 degrees at max load safe enough?
CPUZ says:
Command Rate: 2T
Im happy its got to 3ghz anyway
