overclock gtx to ultra
A GTX might be able to do the core of an Ultra if you're lucky, it will however, not reach the memory speed. That's special to an Ultra ;).
My ( old ! ) 8800GTS 640mb can run at Ultra Superclocked speed on Water :
Mark
Max i can get mine to is 634 on the core and 1033 on the memory. any more just causes it to artifact.
i run it at stock 24/7 anyhow :)
Max I could run my GTX's were 621/2000, but like everything it's all luck of the draw.
Mark
a lot of peoples GTS 640 could run at that speed, infact some peoples GTS 640's could run at 680+ on the stock cooler, mine ran at 650/2.2 then it fell over after that.
Makes you wonder why people are still prepared to spend £400+ :eek: on a card , when an overclocked £120 card will match it :D
Mark
Well a GTS 640 overclocked to same speeds as a GTX or Ultra wont match an ultra lol, the gap will be closed abit, but not fully and then you can overclock the GTX/Ultra and it increases the gap further more. And a, 8800GT is quite abit faster than a GTS 640 too when they are at the same speeds.
I realise that , but is an extra 5/10 fps worth the extra £280 ?
Mark
Mark
Well I think its more than an extra 5-10fps at higher res especially with AA, even my GT is a god upgrade for me from an 8800GTS 640 and 2900XT, performance is quite abit better especially in crysis.
5/10 fps were figures plucked from the air :D
I'm not blindly defending the 8800GTS 640mb , yes its outdated.
But it will run anything i chuck at it @ 1920 x 1200 quite happily.
If i had the money i would upgrade again , but i see little point at the moment what with the 3870x2 and the 9*** series Nvids coming out - prices will tumble in a few months.
Mark
I've left my BFG OC2 at 647/1666/2000 from 626/1450/2000
I can get memory at 2096 if core and shaders left alone but performance in synthetics and games was same as stock
With 655/1685/2096 performance actually dropped !
Biggest single difference for me was increasing shaders, I may try memory at 2050 and try again
Just make sure you use Rivatuner to set fan to 100% instead of the default 60%
Can't be bothered with the voltage or bios mods though, just playing COD4 at 1920x1200 4AA/16AF everything maxed out in every setting and it runs like a dream and looks awesome
648/1620/2052 here with stock cooler and XFX 8800GTX, been flashed like this for over a year. :)
From what i've seen it's rare to see a GTX match the memory speeds but allot of them will beat the core/shader speed which is where the real performance increases come from anyway.
Does flashing give higher speeds/more stability? I wouldn't have thought so, if it's overheating it's overheating. But maybe I'm thinking about it all wrong
