Overclock help
23 Aug 2006
North Wales
Hello i was wondering if anyone can help me.
My system is..
Windows vista ultimate 64
Asus Commando Intel 965 (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 Duo E6600
OCZ 2GB (2 x 1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2
ATI Radeon HD 2900 XT 1024MB
With this setup i have clocked my E6600 up to 3.8
I have now brought anothe 2GB of OCZ pc2-6400c4 http://www.overclockers.co.uk/showproduct.php?prodid=MY-072-OC
so i have 4GB of RAM
However since adding the extra ram my computer will not boot into windows, so i reset all the settings in the bios back to default. It then booted in to windows, so i tryed to overclock it again but i can only get it up to 2.75 now anything over and it will not boot in to windows. Why can't i get it back to 3.8 or as close to?
If anyone can help i will be most grateful.
Thanks.
Hi
As far as I know with the 965 the overclock affect both the CPU and the memory speed directly.
With 4 sticks you have 2 pairs operating in parallell so the load on the channels is increased.
Usually with 4 sticks you have to either reduce memory speed or slacken off the timings a little. eg 5-5-5-18
Regards
AD
