Overclock & PCI-E Frequency possible issue?
13 Dec 2009
Plymouth
Hi All, I currently have my setup in my sig overclocked to a very stable 2.88Ghz, but i thought id have another go at getting a better overclock which im in the process of at the moment, I have set my motherboard jumpers to strap the N/B at a higher voltage, which in turn puts my fsb:dram ratio to 1:1 which is what i need it at to get the results im looking for.
While adjusting my fsb anywhere upto 333Mhz my PCI-e frequency stayes at 100Mhz which is great, but i want to up the Fsb for a higher overclock the problem is if i increase the fsb above 333Mhz the Pci-e jumps to 103Mhz fixed (grayed out in bios).
My question is is it ok for the Pci-e freq to be at 103 or not,will it cause any adverse effects on the system or overall performance...
All my adjustments are done in bios the Asrock Oc tuner is in the screenshot just for info.....
Any help would be great.....:D
Cheers puma luke i have also had a search online and found that it doesnt really have to be at 100 all the time, but anyhow i have had to give up on my mission with this as my mobo is complete and utter rubbish......so until i can get a P5Q deluxe or similar im having to stick to my current overclock.......Thanks for your input much apreciated......
