Overclock problem
23 Oct 2002
N Ireland
When running Orthos on the PC in my sig. it normally stops any-time between 17 minutes up to 8+hours. This is at stock :confused:
It was running just fine @475 X 7 until i had to RMA some Crucial Ballistix RAM. Now I am running 2 x 1GB sticks of double sided and 2 x 1GB sticks of single sided (the RMA replacement).
I occasionally get the BSOD with a variety of error messages.
I used Acronis to restore a clean image of Vista 64 but no luck.
Any advice welcome.
Have you run Memtest86+ with both kits installed?
It's quite possible that they are not fully compatible.
Also on this forum people are reporting the single sided chips don;t overclock as well as the double sided.
Therefore you have two problems: Incompatibility between the chips or the new chips not been as stable as the old ones at high clock speeds
