- 7 Jun 2011
What's the full spec of your computer.
They have got to be the easiest chips Ive ever clocked.
If you have a half decent cooler you can easy get it to 4ghz
What cooler do you have on the CPU?
Stock cooler then.. you really need to think about replacing the cooler with something else before you overclock much higher as temperatures will begin to be an issue.
You have a stock cooler, you want an aftermarket cooler. Depends how much you're willing to spend. Something like this is good value for money and will keep your temperatures lower.
Much much better then![]()
