Overclocked Bundle help?
27 Jan 2009
Hey, i purchased the Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.60GHz Overclocked Bundle https://www.overclockers.co.uk/showproduct.php?prodid=BU-063-OE (with 8GB RAM) and i'm just wondering how to see if the overclock is there? I did look in the BIOS and can see the OC profile which i've clicked on to load.. I contacted overclockers via webnote and got back a reply to download CPU-Z and Prime95 which i've done.. then it tells me to look at the images included, but there are no images in the reply. It tells me they show what to have checked in Prime95, so i don't know what to do if i can't see the images. Can someone help me out please?
While CPU-Z is open and running on the desktop, also run Prime95 and have a look at the core speed reported by CPU-Z.
Ok open up prim and click on just stress testing , then select In place large fft's and hit ok. This will put your computer at pretty much full load , then open cpuz and look at the bottom left of the cpuz display it should say core speed then a number , what is the number ?
