- 30 Oct 2014
- Norfolk
So ive looked into overclocking my i7 4770K, but not sure where to completely to start, any advice/guides/tips would be appreciated
Theres many guides out there, you wanna find one on the same make mobo as you so it uses a similar bios, will be easier to follow then.
What motherboard, cpu cooler do you have ?
The Gigabyte Z87/Haswell Overclocking(OC) Guide
http://www.overclock.net/t/1401976/the-gigabyte-z87-haswell-overclocking-oc-guide
Install the big cooler you have first, the stock coolers can just about cope with stock speeds.
Then just follow the guide, its hard to break anything, if your not sure about anything in the guide just ask in the forums to make sure.
