Overclocking 7950 help
5 Feb 2012
Hey, im trying to up the voltage on my 7950 to overclock as its unstable on the stock voltage (sapphire version)
Is VDDC on saphire trixx the voltage to change? i tried to change it, hit apply, eevrything seemed fine but after a reboot my vddc was back down to default again? anything im doing wrong or need to setup?
on MSIafetrburner i cant click the voltage slider atall even after ticking unlock voltage in the settings :S
I mean its unstable at stock voltage overclocked. at default clocks its fine. Trixx same questions apply, is it vddc i change? and how do i get it to actually save>?
There is a checkbox somewhere which says "save settings", or "apply clocks when windows restarts", something like that. Just look through all the options and checkboxes.
