This is driving me crazy, hope somebody can help me with this.
I've decided to overclock my amd 8350 black edition using the hydro h80 closed loop cooler. Im starting to realise why people spend £££ on motherboards unlike my crappy gigabyte 970a dsp3.
So i've disabled all the power saving settings in the bios and enabled high performance computing and load line control. Now this board still undervolts under load even when using llc so ive adjusted the cpu vid to bring the actual cpu vid inline. Because if this im using amd overdrive to overclock and this is where the big problems start.
While running the stress test at stock the voltage drops by only 30mv so i get 1.2200 instead of 1.2500. This is fine but if i up the voltage to say 1.3250 it will drop again by 30mv but every 10 or so minutes plunge to 1.2200!
The other problem i have is that as soon as i go over 1.3250v on cpu vid my multiplayer goes back to stock. This is instant which leads me to believe it cannot be heat related.
Would really appreciate any help.
Cpu does not go above 50c.
Good that you've got it sorted now though
sorry for my scare mongering!
