hey all,
Just after some pointers on how to clock my q6600 to around 3ghz. Been an AMD blokey for far to long so my knowledge of intel is nadda.
I've got a Gigabyte GA_P35C_DS3R to tinker with so if any one out there has the same set up, what do i need to change. So far i've changed the vcore to 1.35'ish and set the multi to 9 and the fsb to 333.. and it boots fine but prime fails instantly.
My ram is Crucial Ballistix 8500 so it should be up for the task.. but do i need to change its voltage.
Or is there anything else i'm missing?
Cheers
Oh yeah, its being cooled by water so temps should be manageable
Cheers
