- 26 Feb 2010
- Surrey, UK
Potential System Setup:
i3 540:
Stock speed = 3.06 GHz
Multiplier (locked) = 23x
3060 / 23 = 133 MHz Base Clock
Motherboard:
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard [GA-H55M-UD2H]
(used in some of the overclockers.co.uk OC i3 full system builds)
RAM:
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz
Total cost in this week's sale = ~£200 (+ a GTX 460 1024MB)
So overclocking settings on this setup.
I am looking for a light overclock for gaming, possibly on stock cooler (but maybe will consider buying an Arctic Cooling Freezer 7 CPU cooler). I do not want to turn up volts too much.
So if I got this right:
the RAM will be at 1333 MHz, which you divide by 2 to get to 667 MHz.
what kind of ratio does this have to be in with the CPU's Base Clock?
at stock settings, it would be 133 : 667 which = 1 : 5
so if I was to increase the Base Clock to 167 MHz, it would be 167 : 667 which = 1 : 4
base clock of 167 x 23 multiplier = 3841MHz...?
if I wanted to hit 4GHz, I would need a base clock of 174 MHz...?
4.2GHz = 182MHz base clock...?
Question 1: Does the base clock : memory ratio need to be a certain value to get a stable overclock? i.e. does running a base clock of 174 or 182 MHz and a memory speed of 667 MHz (->1333MHz) give a stable overclock
Question 2: Is it worth it to buy an aftermarket cooler for £20 or so?
Question 3: Does the i3 540 CPU come with thermal compound pre-applied to the intel heatsink, or do I need to purchase some?
(I have some experience overclocking a Q6600, but things have changed a bit from LGA 775 -> LGA 1156...)
i3 540:
Motherboard:
RAM:
