Hi
Sorry if I'm being stupid but I seem to be having a problem Overclocking my
E6850, the multiplier is set at 9 x 1333Mhz = 3GHZ stock speed
Now I changed it to 1400Mhz 9 x =315Mhz it should be 3.60MHZ I also tried
1423 x 9 = 3.20Mhz and I thought it should be 3.80Mhz now the only change I made is with the FSB
What am I doing wrong the spec of my PC is below, I did have a E6660 and all I changed with this Cpu was the FSB to 1333 x 9 and I reached 3Ghz on air with no other changes, now I'm sure its not the Cpu,
Intel Core 2 Duo E6850 "LGA775 Conroe" 3.00GHz (1333FSB)
Zalman CNPS9700-LED CPU Cooler
Asus P5N32-E SLi nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
OCZ 2GB (4 x 1GB) PC2-8500 1066MHz Reaper HPC Edition Dual Channel DDR2
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
2 x Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache RAID 0
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache
Creative Sound Blaster X-Fi Platinum Fatal1ty 7.1
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Antec P180 Advanced Super Midi Tower Case
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor
Razer Tarantula Advanced Gaming Keyboard
Razer Diamondback
Creative Fatal1ty Gaming Headset
Vista Ultimate 64bit
2 x Noctua NF-S12 800RPM 120mm Silent Case Fan - 3 Pin
3 x Antec 120mm Silent case Fans
Netgear DG834N 270Mbps RangeMax NEXT Wireless ADSL2+ Modem/Router
Netgear GS605 5-Port Gigabit Desktop Switch
Many thanks for taking the time to reply
Exib
Razer Diamondback
Exib
