Overclocking: Fatal Error (Rounding)
on my motherboard I had to enter the Bios and then press Ctrl & F1, that then allowed me to access "Advanced Chipset Features" where ram timings can be modified, though this may be different for your Bios/Motherboard.
What is the stock speed (MHz) that your RAM runs at? It'll more then likely be the increased speed that is not allowing your RAM to tighten up. Though I have to say, that is a cracking AMD overclock!
I think its 667? And I think its at 740 now, if I got my readings/figures correct. I dunno lol.
Maybe I should replace it with the more expensive 1066 stuff lol. No, calm down, I had a budget and I stuck to it. :eek:
Cheers mate - couldn't have done it wothout the hlep from you guys on here.
Funny really, I'm wanting to push it further like this, I mean this system is such a dramatic improvement over my previous, you'd wonder why I'd wanna overclock at all..
AMD Athlon 3200+ 2.2Ghz
2GB DDR Crucial RAM
Geforce FX 5500 128MB then onto ATI x1650Pro AGP 512MB
Then there's my partners Celeron 633 which she uses that came with 64MB SDRAM stock..... :rolleyes:
