GPU-Z
Ok theres a problem
on these nvidia cards gpuz only shows you there target boost.
Which is basically useless for example mine right now show me at 1150mhz when i'm getting 1300mhz.
The actual core clock you get should be higher you need to use something like msi afterburner and look at the graph.
Where it says core clock mhz is what you are actually getting
