Hi all, I've just upgraded my pc in a huge way.... ill tell you my specs then ill tell you my problem:-
Motherboard: Gigabyte Ultra Durable 2 GA-MA-790XT-UD4P
CPU: Phenom II x6 1090t Black edition (Water Cooled)
GPU: Crossfire 6870 Black Edition
RAM: 2x4GB DDR3 EVO CORSA DUAL CHANNEL (PC3-14900 1866MHz C9 & C10 EVO CORSA DUAL CHANNEL)
PSU: Corsair 850W Modular
My problem is.... I want to over clock my CPU to around 4GHZ, 3.8 GHZ minimum with awsome performance... When ever i go over 3.8 MY PC crashes when windows loads. OR when i change settings like HT Link Frequency or CPU/NB Frequency My pc doesnt even load and im forced to reset CMOS. So the only setting im changing is the multiplier at the moment. C1E Disabled and CnQ Disabled.
Any one know what settings i should be using??? OR a good way to find the perfect settings for me?
Thanks in advance would very much appreciate any ones help
Any tips on voltage ? and the rest?
