Hi All,
I have this setup that I have just got up and running:
OcUK IMP microATX case
Asus P8H61 MX Intel H61 (Socket 1155) DDR3 Micro-ATX
OcUK Value 500W PSU
TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit
Intel i3 2120 3.3ghz
Now OcUK have just sent me this email:
Now I've looked in the bios, which I have to say, is much different to any bios i've navigated my way round before! It says to go into overclocking, but that option doesn't exist. I've gone into advanced mode and AI tweaker, like the user manual says, but almost all of the settings are set to Auto and can't be changed I dont think.
Anyone have any pointers for me? I'm used to basic bioses of old, not this new stuff!
Thanks
James
OcUK Value 500W PSU
Here are the tweaked overclock settings that will need to be entered into your bios which should allow a stable clock of 4.5Ghz
Enter BIOS
Select Overclocking
Adjust CPU Frequency - 45
Adjust CPU Ration in OS - Enabled
Internal PLL Overvoltage - Enabled
DRAM Frequency - Link
Adjusted DRAM Frequency - 1600mhz
Spread Spectrum - Disabled
Vdroop Control - Auto
CPU Core Voltage - 1.395v
DRAM Voltage - 1.6v
CPU PLL Voltage - 1.86000v
Thanks
James
