Overclocking Help
18 Jun 2009
North Lincolnshire
i have recently bought and installed:
CPU
http://www.overclockers.co.uk/showproduct.php?prodid=CP-246-AM&groupid=701&catid=6&subcat=803
MOBO
http://www.overclockers.co.uk/showproduct.php?prodid=MB-195-GI&groupid=701&catid=5&subcat=
I want to upgrade my CPU by upping the multiplier a bit but i can't see the option anywhere in the BIOS even if i press CTRL+F1 for advanced, on overclocking programs the option is grey'd out to change the settings.
I've updated the BIOS to the latest so i don't know whats the problem?
I have one of those boards and they dont clock well at all, if you must ctl & f1 go to advanced it should be there. you might have to change auto to manual in there for the options to un grey
Thanks for the reply.
I see an option for changing the processor speed (go's up by 1Hz) but i can see the mulitplier tool.
