Overclocking Help
20 Dec 2010
Hello all!
Im seeking help on overclocking the bundle i just bought from overclockers.
Processor: AMD Athlon II X2 250 @ 3.0GHz
Mobo: MSI GF615M-P33
Memory: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel
Graphics Card: Nvidia GeForce 9800GT
Case: Coolermaster Elite 430 Windowed Case - Black
Cooling: x1 120mm fan in Case and AMD Stock Cooler for Processor.
Power Supply: Standard 450w PSU (Upgrading to 750w in a month or two)
http://www.overclockers.co.uk/showproduct.php?prodid=CP-248-AM (Processor)
http://www.overclockers.co.uk/showproduct.php?prodid=MB-150-MS&groupid=701&catid=1903&subcat=1483 (Mobo)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-183-OC (Memory)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-214-CM&groupid=701&catid=7&subcat=29 (Case)
the Mobo has a Easy OC Switch (which im not aware of what this does) i have recieved these but not fitting anything together until christmas day.
Basically atm i have a Intel Pentium E2140 which is easy to do, and i just want to know what a safe Overclock is for the AMD and what settings i should change.
Thank You
Google 'overclock athlon x2 250' and check out the first few results. Not sure I can post the links here but look as if they should give some pointers.
Can't help directly as have Intel.
I would reply in a more positive way but do not know the MSI brand of AMD motherboards at all.
