- 7 Dec 2011
Gradually firming up my i5 2500K configuration.
I was wondering if anyone had some guidelines as to CPU cooling and how far you could overclock for how much money (assuming your case and fans can dump the heat)?
Just seen another response which said a Gelid Tranquillo was good for mild to medium overclock.
So on a scale of expected GHz for each cooler/cost level.
(1) Stock cooler - free - ?GHz
(2) Gelid Tranquillo - £31 including shipping - ?GHz
(3) ?
There must, I assume, be a 'sweet spot' where you get the best mix of cooling power and cost.
Cheers
LGC
*********** For those starting at the top and skipping the middle
the target is now to find a cooler which is 135mm high or less *****************
(3) ?
Cheers
LGC
P
