I tried overclocking my i5 2500k earlier with my Gigabyte P67A-UD4-B3 using this guide. However, after doing a bit more reading, I really shouldn't have changed the BCLK or moved the DRAM voltage up so high... No wonder the PC kept looping back to the BIOS screen and wouldn't load windows.
Anyways, everything is back to stock speeds now and I've had no issues. (I've been dl'ing Shogun 2 from steam for like 12 hours and according to realtemp the highest CPU temperature has been like 34 degrees). However, there's no point me having a k series chip if I don't OC it.
So basically, being a newb, I just want to know what I have to change in the BIOS to get a stable overclock. Is it possible to simply move the CPU frequency to 4.5ghz and the Vcore to approx 1.35 and just leave it at that, or will I have to change something else to get a good, stable OC?
If anyone has managed a good OC with the same CPU/board as me your help would be appreciated!
Thanks
Thanks
