Overclocking i5 2500k... My First Overclock
Had been pulling my hair out not able to get past 4.4ghz stable.
Am now running 4.8ghz at 1.43v idle 38c max 60c
Now i have only just set this up and quickly run cinebench 11.5 got a 7.51 score and i know i have not exactly tested for stability via prime95 intel burn test etc it might not even be stable but i had to post to say now i know its not a ram issue or bad board or chip
1.43v? Sounds a little high to me but those temps look ok so I wouldn't worry too much. Can't figure out why it wouldn't run at 4.6 or 4.7 with both modules of RAM though. Give it some Prime and make sure that none of the cores shut down and make sure you get a good temp measuring program. If you're only getting one reading thats probably your board reading. You need readings from all cores.
Your voltages are high - regardless of your low temps - you need to find a happy medium, the highest clock you can achieve within the recommended safe voltages.
Below is a quote from OC's Gibbo for recommended settings for clocking the sandybridge.
Hi there
Right guys myself and our technical guys have spent the entire weekend and this morning in discussions with Intel regarding the alarming amount of reports of Sandybridge CPU's dying and have been conducting our own testing as have Intel to find out what is a definite no no.
Sandybridge maximum safe voltages
Core Voltage - Not recommended too exceed 1.38v, doing so could kill the CPU, we therefor recommend a range of 1.325-1.350v if overclocking.
Memory Voltage - Intel recommend 1.50v plus/minus 5% which means upto 1.58v is the safe recommended limit. In our testing we have found 1.65v has caused no issues.
BCLK Base Clock - This is strictly a NO, anyone using base clock overclocking could/will cause damange to CPU/Mainboard. (Set manually to 100)
PLL Voltage - Do not exceed 1.9v!!
Processor - Basically we recommend customers not to exceed 1.35v to play it safe, all our bundles are set at 1.3250v or lower, any competitors offering bundles above 4.6GHz you should be enquiring as to what voltage they are using as we believe anything over 1.38v will limit CPU lifespan and anything over 1.42v will likely kill the CPU or severely limit its lifespan.
Memory - Intel recommend 1.50v plus/minus 5% which means 1.60v is the ideal safe maximum, but we have found in our testing all 1.65v memory is fine. We have also found most new 1.65v like Corsair XMS3 will run at its rated timings with just 1.50-1.55v which is well within Intel specifications. So people upgrading to Sandybridge you can still use your old DDR3, but we do recommend you run it at 1.60v or less. We are shipping most of our bundles which feature Corsair XMS at 1.50v-1.55v at rated timings. We've also discussed with Asus and MSI regarding voltages for memory and they also confirm in their testing 1.65v caused no issues with reliability.
Base Clock - To put it simple if you value the life of your components, do not overclock using base clock!
PLL Voltage - Again do not exceed 1.9v!
These are just guidelines we recommend you follow, if you want to push more voltage through your CPU's then just be aware they could die on you. Your warranty is un-affected and we will honor any CPU's that die, we just won't ask questions as to how you killed them. ;)
Not all CPU's are as fragile as others, we have experimented upto 1.50v Vcore and 1.70v memory and had zero issues with reliability, so it seems some of fine when pushing hard. :)
thanks for the info plec
am running at 4.7ghz 1.39v - 1.43v depending on load
noctua NH D14 cooler max temp 58c
Using C1E powersaving mode too so it drops down to 1.6ghz and 1.09v at idle
all settings altered via bios
was stuck at 4.4ghz as CPU PLL option in bios was set to auto and i thought
that meant it was enabled and it wasn't lol
so changed it to enabled and it overclocks fine now, had to set voltage to normal
and dvid to +100 which gives a max of 1.44v if needed
Update: just reset bios to 4.6ghz at 1.37v plecs info makes alarming reading.
only had this intel setup 4 days no point killing cpu
A couple of hundred MHz isn't going to make any difference in your day to day running. You've still got a great clock using air coupled with acceptable voltages.
With my rig (see sig) i decided on a respectable clock with minimal voltage and speedstep enabled. It's not out and out overclocking but there's a certain satisfaction to be had out of getting a substantial clock using minimal voltages.
If you're after another challenge try it out - it's surprisingly satisfying.
i will give it a go how did you set voltage?
in bios did you use dvid or just a manual input of 1.19v?
i have speedstep on also i really like the fact it will idle at 1.6ghz when surfing the net etc
