I have my 950 clocked at 4.38 GHz with the ram at 1900 MHz, I think the multi is 23 x 185 but the temps are way up on what I was expecting there sitting at 46c + and desperate to climb, I had a 920 C0 prior to this which was at 4.2 GHz and it sat at 36c idle and I thought the C0's were supposed to be the hot chips, the voltage is set to auto which it was with both chips (1.425v)which is quite high but why is the D0 stepping chip so much hotter than the C0 chip.....the ambient temps have been higher recently due to some very good Scottish weather but I have 2 x rads (1x 360 with 6 x noctuas push/pull and 1 x 160 with 2 x noctuas) that do just the CPU just now so the temps are normally good, I use mx-4 which I did on the 920 as well so would an extra 200 MHz on the chip and 250 MHz on the ram create this much extra heat? other 950 owners what do you have your chips running at and what multi's are you using please?
