Overclocking issues
11 May 2010
Hey.
I have tried to overclock my i5 2500k many times in the past and also recently. But for some reason it just doesn't want to happen. The motherboard I'm on is a Gigabyte Z68AP-D3 and I'm using a Gelid Tranquilo cooler.
But to be honest I dont think its heat related at all.
What happens is, I will try the overclock (using this guide http://forums.overclockers.co.uk/showthread.php?t=18375640) and all will be well for a while. Temps will be fine during stress runs and gaming.
But then eventually I will get a blue screen, usually on a reboot. This will then automatically reset the overclock back to stock settings. Now I'm by no means very savvy with overclocking so maybe I'm just doing something wrong but following that guide seems pretty painless.
Even for the 4Ghz overclock I get the same issues.
Its just a shame that I cant seem to get anything to work when I have such a great CPU for OC'ing.
Does anyone know what might be causing the problem?
Cheers!
On that combo which I used to have the symptoms you describe are down to not having enough V's - power. I used to get the same thing until I managed to get it stable at 4.8ghz following a guide on that thread.
the below got me 4.8ghz stable with none of the symptoms of it resetting etc.
Advanced Frequency Settings -
CPU Ratio - 48x
Advanced CPU Core Features - Press Enter
Internal CPU PLL Overvoltage - auto
Real Time Ratio Change in O/S - Enabled
Intel Turbo boost tech - Disabled
Press Esc
System Memory Multiplier - 16.00
Press Esc
Advanced Voltage Settings - Press Enter
Load-line Calibration - Auto
Dynamic Vcore - 0.160V
System agent - 1.055V
QPI/VTT 1.24V
PLL - 1.94V
Dram Voltage - 1.6V (depends on your memory)
Advanced Memory Settings - Press Enter
Performance Enhance - Standard
set the next line down to Expert
and disable all the C states etc.
