Gigabyte GA-965-p v3.3 fireware 12a
Geil 800hz ddr 2 -2gb
2xSata WD HD
E6600 2400
Antek 550w PSU
Running latest ATI drivers.
4870 ATI 1gb saphire
I have tried numerous Changes to the FSB but i cant get it to run at
333.
320 seems to bsod but it does boot
and 300 seemed ok..
i have disabled all the advance EIST etc...
My current settings are
3. In the Advanced Bios Features Menu, Disable all of the following: CPU Enhanced Halt (C1E), CPU Thermal Monitor 2(TM2), CPU EIST Function
4. In the PC Health Status menu, set the FAN Speed Control Method to "Legacy" & FAN Speed Control Mode to "PWM" to maintain highest speed
5. Go into the MB Intelligent Tweaker (MIT) menu at the bottom of the page, set the System voltage control to "Manual"
6. These boards have a default VDIMM of 1.8v, set the VDIMM to co-ordinate with your ram. The Geil I have is specced as 2.1v so I have mine set to +0.3v
7. Set the MCH Voltage to +0.1v
8. Set the FSB Voltage to +0.1v
9. Set the VCORE to 1.375v - Please be aware that this will increase temps!
10. Set the CPU Host Clock Control to "Enable"
11. Set the System Memory Multiplier to "2x"
12. You're set to go, just increase the System bus Frequency to Overclock
2xSata WD HD
E6600 2400
Antek 550w PSU
333.
and 300 seemed ok..
