Well can't seem to find the right VCore lol, tried 1.525, 1.53, 1.54, 1.55, 156 and none seem to work lol!
Anyway I have to go soon, got college tomorrow didn't see the time lol ;p, do you think we could continue this tomorrow?
Sure, no problem. Don't keep raising and raising vcore, it might just need a little tweak elsewhere, let me think about that one.
1.54 (1.47 during load) should be more than enough to get toward 3.6ghz. It will just depend if your chip and board are up to the task. Some do, some don't, its a case of trial and error.
EDIT - just a thought, but maybe it doesn't like the FSB over 400, so you could try this...
CPU RATIO - 9x
FSB - 378
CPU Vcore - 1.52
CPU PLL - 1.55
Northbridge - 1.35 (might need 1.4, but try 1.35 first)
FSB Termination - 1.25 (might need nearer 1.3, but try 1.25 first)
This again will get you running at or around 3.4ghz.
EDIT2 - do you have the optional cooling fan for the heatsinks that some of these motherboards came with? If so, get that hooked up as it will help keep things nice and cool. If not, it might be an idea to get some form of active cooling on there, as these things can seriously heat up when Priming.
EDIT3 - Did you get Asus PC Probe working, and if so, did it list temps for Northbridge etc?
EDIT4 - What Northbridge Strap (FSB to Northbridge) are you currently using?
EDIT - Its got 1 temp showing for the CPU which is 19c and at load its 35c but not sure if thats it =]
