Overclocking problem
8 Apr 2007
Hi Guys,
Recently got a new build i5 2500k SandyBridge 3.30 Processor, Asus P8Z77-V PRO Intel Z77 (Socket 1155) DDR3 Motherboard, with the samsung DDR3 ram which Gibbo recommended for the OC'ing ability.
I have the I5 2500k running at 4544.54 MHz x45.0 - Bus Speed 100.99 Mhz - @ 1.384V
When running Prime95 it will run Tests on all 4 Cores - However Worker Number 4 which is coming up CPU3 will start Test 1, 4000 Lucas-Lehmer Iterations of M19922945 Using FFT Length 1024K but it will hang on this while CPU0/CPU1/CPU2 will run through tests 1 - 15.
When stopping the test all come back with 0 Errors / Warnings.
So my question is why is Worker 4, CPU3 holding at Test1?
Many Thanks
