Got my E4300 yesterday and set all the parts up (Gigabyte DS3+2GB Patriot PC6400 ram). Installed a fresh copy of WinXP and everything went fine.
I decided i may aswell try my hand at overclocking since that was the main reason why i bought the E4300. I went into the bios and manually changed the timings and ram voltage to the rated 4-4-4-12 and 2.2v and set the divider to 2x. I then disabled the extra stuff that is not needed like Speedstep etc. I increased the fsb from 200 to 220 and restarted. However, the screen was blank and i could still hear the fans running. I restarted a couple more times and finally got into windows. I tried Orthos but it failed after about 30secs.
I lowered the fsb to 215 and it still didn't boot properly. I haven't tried increasing the vcore, just kept it at stock 1.325v. I haven't downloaded the bios from the Gigabyte website cause in CPU-Z it says that they are f10. I have tried losening the timings to 5-5-5-15 and it still causes problems.
Any ideas of what im doing wrong? It all seems to work fine at stock.
. I didn't think i would need to increase the vcore so soon in overclocking. I thought i could get up to at least 2.2GHz on stock voltage.
