Hi
Thank you for letting me join this forum. I have been trawling various threads and your very insightful help guides to overclocking, but I'm still very unsure how to tie my ram into given settings.
Existing kit
Q9770
4X 2Gb XMS2 8500 1066 5,5,5,18, 2.1V
Noctua Nh-d14
Asus P5Q premium motherboard
Existing settings
Existing settings
CPU ratio setting 9
FSB strap ~Auto
Dram frequency ~Auto
DRAM CLK skew A1 ~Auto
DRAM CLK skew A2 ~Auto
DRAM CLK skew B1 ~Auto
DRAM CLK skew B2 ~Auto
CAS latency 5
CAS delay 5
precharge 5
activate to precharge 18
Dram voltage 2.1V
I'm currently running at 3.6Ghz stable
My ram is showing as DDr 800 at startup, how do I get my RAM to run at its 1066 rated setting based on the settings above?
Thanks in advance
Tim
Many thanks in advance
Existing kit
Q9770
Noctua Nh-d14
Existing settings
Existing settings
CPU ratio setting 9
FSB strap ~Auto
CAS latency 5
CAS delay 5
precharge 5
Dram voltage 2.1V
Thanks in advance
Tim
even 5 years ago I'd have had tons of information to hand but these days I can barely recall anything - though I still have a Q9550 system on the side - I got around a lot of the issues with FSB straps, etc. simply by running some crazy OCZ Blade ULV RAM that does silly speeds with ease. (Actually modified DDR3 RAM on a DDR2 Dimm).
