Hello,
I'm dumping my LGA1366 system now that the (socket 1366) mobo prices are inflated, I will actually even get some money back from going to a 2600K + P8Z68V/GEN3, as my just Asus P6T is worth as much as I bought the 2600K + P8Z68V for... And the i7 940 is still worth 3 or 4 tenners or so...
I'm new to this socket however, is it as simple as upping the CPU multi like some say so ? 1.4 vcore volt max as a safe ''limit'' from what I can gather. Cpu is cooled with a 120mm dual fan water cooler.
I will be using 3x4gb 2000mhz c9 DDR3 that is rated at 1.65V, should I manually meddle with the volts, or just put the mobo in XMP mode and leave it on auto ?
Should 4.5 ghz be doable ? And if so, what do I have to watch on this socket ? On my old i7 I still oc-ed by upping the base clock ( and having to watch uncore freq and QPI link speeds, and meddling with the ram controller voltage on cpu)
