gogogo overclock!xirokx said:i just thought it would be going much quicker i guess....so if i overclock you reckon i will see a vast improvement?
Mikey1280 said:Does transferring files between hard drives actually stress the cpu much, I thoug ht the hard drives would be the limiting factor
I rarely stress my cpu at all. Harddrive should really be the limiting factor. But go ahead now, and overclock that No swearing!
Next time I resit my heatsink I reeally must remermber to put an external temp sensor on the chipsablabra said:You can't really trust the sensors anyhow. If you have DFI, you might as well just add 10c. Hence why they included it in the newest bios
PinkFloyd said:Next time I resit my heatsink I reeally must remermber to put an external temp sensor on the chip
I can't believe it is 10 degrees out though tbh...
xirokx said:however when loaded cpu at below settings cpu temp is 50 deg and PWIM (what is this btw) was at 52deg and was in RED on smart guardian so this cant be safe?
