- 26 Nov 2003
- East Sussex
Just trying to work out the best way for using the auto tools on ATI Tool, should you do the GPU clock auto, then write the setting down and reset it to default before doing the memory one? Or vice versa?
The idea is doing them individually, so that the changes made to GPU wont affect the auto finding for the memory.
Then set both to the values you wrote down.
Could however, the combination of two highest be unstable because they didnt take into account the overclocking done to the other setting?
