overclocking X1950pro
  • Thread starter Thread starter uv
  • Start date Start date
uv
uv
16 May 2006
Manchester
Howdy :)
I have an X1950pro Turbo, which is factory overclocked, albeit not by much.
It has the IceQ cooler, so it's pretty cold (and silent ;))
Only thing is, it clocks for peanuts. I can get, say, 10mhz more on both core and mem..
Has anyone tried volt modding this card? And is there a way to change the volts without modding it's Bios? And has it produced any decent results on this card?
Cheers!
uv
my x1950pro agp hardly clocks up much at all, i just left it at stock since the 7mhz extra it got on the core was just not worth the hassle. odd though since the x1950pro is 80nm and the x1900xt i got is 90nm and clocks much higher.
im guessing its something to do with power getting to the core or something.
my x1950pro was like that. I think it would run at 600/1500 but didnt really make any difference. The only way i could tell was by the heat
It was exactly the same for my X1900XT, with stock cooling and Zalman VF900 it only clocked slightly higher.
But with a Accelero S1 it's at 688mhz.
[ZiiP]carrot;10914200 said:
Got a HIS cooler version here, dunno if its pre-overclocked (580/770) but I can't overclock it at all:mad:
O well, 8800gts/gt next:D
Thats standard clocks. have u got ati tool?
Actually, if you have ccc use the overdrive function.. and let it run, then when it starts gettin funny reboot and then just take them back 5.
