First of allIm having overheating problems with my cpu, an Intel Core 2 Quad 2.66GHz (Q6700) and i dont know wether its because of my heatsink (an Akasa 961) or if thats the normal temperature it should have. The temperatures of my CPU at idle are around 55 to 58 C on all cores. I use Core Temp and many other teamperature reading softwares to read the temp and they all give the same readings.
Here are some of my system specs:
Motherboard: Intel DP35DPM
Power supply: Akasa P100FG (1000 w)
Ram: 2Gb DDR2
The comp case has 3 fans so ventilation isn't a problem.
Don't know if that helps at all.
I have tried re-mounting the heatsink to made sure its on properly. I also added my own thermal paste (Arctic Cooling MX-2 Thermal Compound), just a rice grain amount, which I think is the recommended amount. Maybe I just need a better CPU cooler? If so then which one would you guys recommend?
Any advice would be helpful
Ram: 2Gb DDR2
