- 3 Aug 2018
I've recently bought a 9700k and have for the first time started overclocking and i'm running into extreme temperatures and I cannot figure out why. I had a budget 240mm aio which i've just replaced with a 360mm Arctic Freezer II and i'm still getting bad thermals under stress test, maybe worse somehow?!
My overclock is 4.8ghz, 2 AVX offset, 1.325v, LLC level 6, and my motherboard is a Z370-F.
Idle temps are 28-30c which sounds good, but even opening chrome will spike to 60c no problem. In fact when I first boot up and check Core Temp it shows 50-60c max just loading windows stuff, and on smallest prime 95 I hit 98c on some cores in under 10mins and I'm scared to run it any longer...
I want to lower my LLC or vcore, but my vdroop is awful. Getting 1.296v load voltage on 1.325v vcore so i'm worried to lower it due to instability (according to CPU-Z).
Cinebench R15 maxed out at 74c though. So what could my issue be since I saw people reporting 67c load temps on 9900ks with this cooler.
Please help
Please help
