P182 for £45.99 wtf!
23 Apr 2009
Glasgow
Just saw this in the b-grade section, what is wrong with it so that it sells for this price? I was planning on buying an ft01 or maybe a raven2 in the near future but I must say I am very tempted at that price.
Haha, bargain!! Ive seen quite a few cases go from the clearence dead cheap and often the problems are trivial little things. Nice buy, let us know how it is :)
most cases in that section have nothing wrong with them
a few screws missing or a scuff or something is generally the worst 'case' scenario ;)
Well I got the email saying its been shipped! So I think this means I will have it tomorrow! Woop!
P.S Very witty rjkoneill :p
Well it arrived, and from the looks of things the only problems were that it wasn't in the original box, nor did it have an instruction manual, THAT'S IT! Hahaha.
Here are some pics anyway, sorry about the ones once its built, bad light/not caring at that point.
Showing the size difference
The old un!
With the door open. There are 2 xigmateks there. The top on is tie wrapped in ;)
Cable management is pretty dam good in this case, and I think I did it ok?
Going to remove some fans from it though as its still a bit noisy! By the looks of it the top exhaust wont be doing a lot. And I may change the other 2 Antec fans. Any other suggestions on how to make it quieter?
I just wish this one was black internal, it does spoil the case somewhat!
Still yet to decide if I'm going to keep it, it hasn't wowed me as much as I thought it would, pretty much due to the noise and colour factor me thinks!
Can easily get the insides powder coated or have a bash your self with some spray paint.
Nice work on the cable management though like you said! much tidier than your old case was (not that it was that bad lol)
To reduce noise you could just volt mod the fans down to 7V or so, or use a fan controller. Using a Zalman fan controller in my rig and its one of the best purchases Ive made! So easy to just turn the fans down when browsing or watching a film, then wack them upto full speed when gaming. Could be a good solution for you :)
Yeah that's what I did with my other, rattle cans ***! Haha.
Cheers :) I made extra holes in my old one to aid it a little.
That does indeed sound like a good plan, I have just spotted a picture of someone else on here's p182 and they have removed the roof exhaust, and don't have the top front one like me. Would this make my case a lot hotter if I removed them or would it actually benefit the airflow?
Top fan wont start on 7V, annoyingly. Turn the TRUE 90 degrees and you can probably turn the front two fans off. Drop the rear fan to low or to 7V & M and the top one to low and you'll be laughing.
Good case.
Really? The top one works on every level in mine. Surely if I turned the TRUE I would still need some form on intake fan?
I am thinking I will replace/remove the antec fans, they do seem to be noisier than my xigmateks
