P35C DS3R - Rev2.0 Problems
28 Jun 2006
I just bought the motherboard and I have installed it. The problem im having is that when I put my ram in (Geil PC6400 ULL 4x1Gb), it won't boot. I got it to boot when only using 2x 1Gb of ram but now the computer only detects 1Gb of ram :confused:
I updated the bios from F2 to F10 to no avail. The ram all worked fine in my 965P DS3 Rev1.0. Any suggestions?
Thank you :)
I have had a bit of a mess about with it now and the update is:
DDR2 Dimm 3 doesn't seem to be working.
The strange thing though is that when I try 2 sticks using DDR2 Dimm 3, it boots but only detecting 1 stick but when I try all 4 sticks, it won't boot detecting 3Gb.
Anyway, should I RMA the motherboard because of the faulty DDR2 Dimm 3 or do you think there is something causing the problem I can fix?
Thank you :)
