P35C overclocking - am i missing something?
1 Dec 2005
Stoke on Trent
Got my Q6600 G0 straight in at 3.2Ghz on above board. Disabled all the usual options in the bios and its run ok.
Tried for 3.4Ghz but when i set the FSB to 378 in the bios and i exit saving changes, when it reboots its reverted back to 356 :confused:
Am i missing something as whatever FSB i set it always reverts back to 356.
I know this board and CPU are capable of 3.6Ghz as thats what the previous owner had it doing
hi there,
what volts are you using i have the same board and have to use 1.45 volts or more to get to 3.6 if you have sufficient volts try upping the northbridge voltage i am at +0.2 volts this may cause a problem for you inn terms of temperatures though. mine is water cooled so i dont have a problem with temps. Also what cooler are you using and what other cooling such as case fans do you have as that quad is ganna be kicking out a lot of heat at 3.6
Got a Freezer 7 pro on the cpu and front and rear 120mm fans.
I tried 1.4v on the cpu and it posts but reverts back to 3.2Ghz for some reason
I dont suppose you could post a screenie of your bios settings?
