I have a P4 570 (3.8ghz),
My stock hs&f was starting to click so I have fitted a Zelman CNPS7700-Cu.
I didn't fit speed control thing to the board becasue I wanted to see how loud it would be like that.
My Mobo is an MSI 7046 (OEM) in the bios there are no temp monitor & the software on the MSI site says it does not support my mobo.
I downloaded a program called speedfan and it reports that the cpu fan is running between 38-43c when whatching somthing on media plater ant browsing net and 60c ish when running oblivion.
So my questions are
1. What should a P4 570 be running at ?
2. Anyone know any better software to monitor ?
Also anything else helpful would be welcome
Thanks for reading
So my questions are
Thanks for reading
