All
I had an issue which I posted a while back with my RAM running extremely hot. Like, 70 degrees or something. This is not right. I have 4x1GB sticks GSkill ram in there. All was well breifly apart from the very hot temperature. I'm running everything (now) at stock speeds.
One of the pairs of sticks was faulty and started failing memory checking and I got it RMAed with GSkill. I put the replacement RAM in and started the computer, and it wouldn't post or beep - just all the fans come on, and the fan on the 8800GTX comes on full wack, and no video or anything. I restart, and it boots fine and i'm away for a bit. Now it won't boot every time. If I take the replacement RAM out (leaving just 2x1GB) it boots fine.
I must have a dodgy motherboard, correct?
TIA
TIA
besides even in a no-air situation you wouldn't expect that heat, surely.
