I'm running my Q6600 @ 460x8 (3680 MHz) and 4x1 GB of ram as a 24/7 setting. Nothing done to the mobo at all, so there really isn't any need to do anything. Sure, it's awfully hot to touch, but it doesn't really seem to pose a problem.
Btw, my cpu and gpu are water cooled, but not the chipset/mobo
. Not really that much airflow. I've got six(6) 120mm fans in the top (3 on each side of the radiator), one 120mm in the back and one crossflow fan. That sounds like a lot, but all fans are spinning slowly and it's a big case (cm stacker). Really, if the chipset heat is stopping you from getting further, you can always strap on a 120 mm fan over the heat pipes.
